Harmonic balancer removel help
In the process of removing the balancer from an 07 tahoe
the bolt that came with the remover tool isnt long enough to make to the threds of the crank shaft. any suggestions? help much appreciated
Since it's pushing against the end of the crank, can you put a spacer like a small socket on the end of crank. Now if it uses the same bolt to put it back on with, that won't work. Probably have to either get a longer bolt or new installer.
Yes finally got it. Jerry rigged something to extend the rod into the back of the crank shaft. Came right out.
Thanks a million.
77scottsdale
October 22nd, 2014 8:45 PM
Daga
March 19th, 2012 10:17 AM
