Harmonic balancer removel help
Old Dec 18, 2012 | 6:28 PM
rcott's Avatar
Default Harmonic balancer removel help
In the process of removing the balancer from an 07 tahoe
the bolt that came with the remover tool isnt long enough to make to the threds of the crank shaft. any suggestions? help much appreciated
Old Dec 18, 2012 | 8:25 PM
Since it's pushing against the end of the crank, can you put a spacer like a small socket on the end of crank. Now if it uses the same bolt to put it back on with, that won't work. Probably have to either get a longer bolt or new installer.
Old Dec 19, 2012 | 4:06 PM
rcott's Avatar
Yes finally got it. Jerry rigged something to extend the rod into the back of the crank shaft. Came right out.
Thanks a million.
Old Dec 19, 2012 | 9:47 PM
Glad to help.
Will the bolt be long enuf to install the new one?
Old Dec 20, 2012 | 1:07 PM
rcott's Avatar
Glad to help.
I sure hope so if not I'll have track down a new installer probably from the dealer
Old Dec 22, 2012 | 8:07 PM
rcott's Avatar
of course got to installing the balancer and bolt is way to short to get to those threads
77scottsdale
Oct 22, 2014 8:45 PM
Daga
Mar 19, 2012 10:17 AM
irving216
Jan 31, 2012 2:38 PM
4wheelR
Feb 12, 2008 3:20 PM
Slimmurph12
Apr 20, 2007 11:50 AM
