have no bat ongray wire to fuel pump. DO have bat pin 30 fuel pump relay.
can't figure out a way to eliminate bad ign sw. Have jumpered 30 to 87 and still pump will not run. where does pump get grnd
yes found that wire it was clean but spruced it up have no batt on relay coil wire so that when pcm gives ground it activates pump relay. I don't have wiring schematics so what gives terminal xx battery ? pcm or ign sw?
The ECM (Engine Control Module) provides the 12V to activate the fuel pump relay.
Fuel system control module,so I took a look,07 Tahoe that I got under,is 3 line pipe system,no fscm,so what do you have,new 1 pipe system,no return?or 2 pipe,with return and pressure regulator on intake
