have no bat ongray wire to fuel pump. DO have bat pin 30 fuel pump relay.
Old Oct 18, 2018 | 1:38 PM
brucej455's Avatar
Default have no bat ongray wire to fuel pump. DO have bat pin 30 fuel pump relay.
can't figure out a way to eliminate bad ign sw. Have jumpered 30 to 87 and still pump will not run. where does pump get grnd
Old Oct 18, 2018 | 4:43 PM
geo1's Avatar
Pump gets ground on frame,near tank
Old Oct 19, 2018 | 12:02 AM
brucej455's Avatar
yes found that wire it was clean but spruced it up have no batt on relay coil wire so that when pcm gives ground it activates pump relay. I don't have wiring schematics so what gives terminal xx battery ? pcm or ign sw?
Old Oct 19, 2018 | 3:24 PM
a55bruce's Avatar
The ECM (Engine Control Module) provides the 12V to activate the fuel pump relay.
Old Oct 19, 2018 | 3:51 PM
geo1's Avatar
So,jumping 30 to 87,no pump,that truck has a fscm,between relay and pump, but where is it on tahoe?
Old Oct 19, 2018 | 4:47 PM
geo1's Avatar
Looked into it more,some have return line,2 line system, some have 1 line,fscm involved,just looked at 07,2 line
Old Oct 21, 2018 | 8:55 AM
brucej455's Avatar
know most abbreviations but do not know fcsm. could you tell me what4 that stands for
thanks Bruce
Old Oct 21, 2018 | 9:10 AM
geo1's Avatar
Fuel system control module,so I took a look,07 Tahoe that I got under,is 3 line pipe system,no fscm,so what do you have,new 1 pipe system,no return?or 2 pipe,with return and pressure regulator on intake
