Having trouble starting Tahoe
Old Mar 29, 2022 | 11:12 AM
jentoe91's Avatar
Default Having trouble starting Tahoe
I drive a 2015 Tahoe. When I turn my key it will click once and then nothing. It will turn over after the third attempt. I went to O'Reilly and the starter, battery and alternator are all good. Any Advice?
Old Mar 30, 2022 | 12:52 AM
ampsweden's Avatar
bad ground somewhere. I have had that also.
Create a ground cable attach it from the negative pole to a bokt on the engine. Beware so the cable does not get hooked in a belt or so.
If it then works, u need to find that ground cable somewhere attached to the body. I think somewhere behind the motor againt the torpedowall.
Check the main ground cable, could be rusted of.
Xyz
Oct 19, 2017 8:53 AM
billyh
Feb 19, 2016 11:42 AM
Ctahoe2015
Jan 18, 2016 9:17 AM
julian734
Aug 3, 2008 8:14 PM
mig644
Oct 27, 2006 10:53 PM
