Tahoe & SuburbanThe power, space, and brutal towing ability make the Tahoe and its longer sibling, the Suburban, arguably the best full size SUV's on the market today.
Hey guys, got the new lights for my 2018 suburban, installed them but ran into a problem, my low beams (h7) are acting like a high beam, they aim very high and in general I can tell that this is high beams ( trust me I tried to adjust it down but same thing) and my high beams (H1) are lights up like my low beams. So at night Im basically driving with only high beams on all the time, and when I turn my original high beams I simply adding the low beams. Well I cant switch the bulbs, since the inputs are different and H1 are build in into the lamp. I was thinking changing the wires on the switch itself so when I activate my high beam the proper light will go on, but I cant find any info if that will do any damage or use a different voltage, amps etc. Any advice will help. changing wires in this plug switching high with low beams, should only be 2 wires
