Heater Hose Connector
Old Mar 28, 2021 | 4:58 AM
revjim1959's Avatar
Default Heater Hose Connector
I have a 2001 Suburban that developed a leak where the heater hose connector connects to the heater core (It is a Suburban with rear heat so they are the "T" shaped connectors. I first replaced it with a Dorman 800-413CD but it also leaked at the heater core connection. I read in a couple of places that the Dorman parts have quality issues, so I went to my local Chevy dealer and bought the GM part. It also leaks at the same place. It seems like a pretty straightforward repair is there a trick I am missing? Thanks in advance.
Old Mar 28, 2021 | 9:00 AM
oilcanhenry's Avatar
Its possible the hose itself is defective or worn out.
Old Mar 28, 2021 | 9:11 AM
Cusser's Avatar
I have a 2005 Yukon. My quick-connect fitting on the heater core inlet (driver side) broke and I used Dorman/O'Reilly 800-403 and it's been fine a few years.
A few years before that my mechanic replaced the T-connector for the heater hose on the engine; he first used GM part but that leaked so he swapped in a Dorman part for that too.
I know other manufacturers also use these ridiculous connectors, but NOT a better idea; I'd prefer old fashioned hose clamps myself.
Old Mar 28, 2021 | 12:47 PM
repairman54's Avatar
Is the connector leaking at it's quick disconnect or is it leaking where connector goes onto the metal pipe. If to the pipe there can't be any burrs or nicks at the sealing spot on the pipe or where the connector slides over the end of the pipe. A little silicone grease on the pipe to lube the rubber O ring inside the connector when it's put on may be needed so the internal O ring doesn't get damaged when putting on a new one.
Old Mar 28, 2021 | 5:54 PM
revjim1959's Avatar
It is leaking where the plastic connector attaches to the heater core, so no hose at the leak.
Old Nov 6, 2021 | 6:21 PM
AnitaPat's Avatar
my 2003 denali is in my driveway broke down. My husband has tried 3 different brands of quick connectors and every one leaks at the connector. HELP
Old Nov 7, 2021 | 8:04 AM
I just had to change those connectors in my '11 Tahoe. the aftermarket ones are all junk. I bit the bullet and got GM ones from the dealer, no problems with them. For me trying to save a few bucks with aftermarket instead of factory connectors was not worth the aggravation.
Any nicks or damage to the aluminum tubes will affect sealing so one has to be super careful taking it apart in the first place as it's a tight spot to access.
trouty
Astro
Feb 13, 2018 7:28 PM
einshotmike
Nov 27, 2015 11:42 AM
Scott Thompson
Feb 3, 2014 3:18 PM
golferwannabe
Nov 24, 2012 8:45 AM
76 Impala
Nov 15, 2012 4:41 AM
