Heats up no movement
Old Aug 31, 2025 | 3:13 PM
Rickyman813's Avatar
Default Heats up no movement
Good afternoon everyone I am new to this forum I have been asking a specific question to get all the help that I can get I have a 2006 Chevrolet suburban 1500 and the problem with my vehicle is strange and don’t understand and I can’t get the correct answer to fix the problem and get the run around.
after my vehicle sit I start it and drive it the minute the engine and transmission heat up it brakes and stops on its own and will not move again once it has sat for a bit and cools down than it drives again and the same process over and over I have been told it was ecm so I replaced that then it was the hydro boost so it was expensive so I just chance the seals and cleaned it up still the same problem the it was the brake calipers so I changed all 4 along with new brakes and rotors now I’m being told it’s the body control module and that’s expensive which I don’t think it is that is there anyone that has been through this that can give me a real answer that can help me out to solve this problem and help or advise I really would appreciate it.
Old Aug 31, 2025 | 5:10 PM
Rednucleus's Avatar
Does the brake pedal get firm and hard to press when this happens?
Old Aug 31, 2025 | 5:24 PM
Yes it does
Old Aug 31, 2025 | 8:16 PM
Rednucleus's Avatar
There is a thread here somewhere on this same problem. Try the search bar; Iwill see what I can find. If I recall the problem is the master cylinder or hydroboost unit
Read this: https://chevroletforum.com/forum/199...rm+brake+pedal
Old Sep 1, 2025 | 9:42 AM
Cusser's Avatar
I think similar issues were linked to a brake pushrod with insufficient free play.
Old Sep 1, 2025 | 8:47 PM
i looked into that message but the only problem with mine is that its is equipped with a hydro boost that is ran off the power steering pump pressure i don't see a vacuum line to it
mtd240
Nov 4, 2012 5:35 PM
coppola7
Nov 22, 2010 11:39 AM
mikef
Sep 18, 2009 8:03 PM
Rustybolt
May 6, 2009 6:04 AM
benndez9
May 25, 2007 7:58 AM
