hello newbie here in need of some help thx
Old Feb 9, 2010 | 10:24 AM
chevyman1981's Avatar
Angry hello newbie here in need of some help thx
hello ever one im new here would like to interduce myslef my name is bobby i have a 2003 chevolert subaburn 5.3 the problem im having is i need to change the blower motor i think my truck will dim lights and only when the heater is on i have done the alternater and no change if any one can help me out here could it be a rester maybe and if so wher is it at and how hard would the blower motor be to change thx 4 all the help i hope u give me bobby
Old Feb 9, 2010 | 10:27 AM
maxxman04's Avatar
you might have battery tested, all cable connections checked to make sure they are clean and tight. maybe change the serpentine belt as well.
Old Feb 9, 2010 | 11:51 AM
gmpartsguy's Avatar
the tahoe suburban and silverados are pertty notoriouse for blower motors and resistors going out. ive never heard of the lights dimming. do this. under the dash on the passenger side there is a black cover. should be screwed in with three or four screws. take that cover off and the blower motor and resistor is on the right hand side. disconnect the resistor connector. the big one. i believe its a seven wire conn. make sure its not melted. if it is, replace the connector and resistor. if you need further help you can call me. 214-472-6803
dingle
Oct 13, 2009 11:14 AM
Nicegirl
Mar 6, 2009 10:26 AM
deejayrock
Sep 20, 2007 1:07 PM
99tahoe5.7
May 20, 2007 2:31 AM
deejayrock
Feb 16, 2007 4:16 PM
