Help 02 suburban reduce engine power when i jumped it in the morning.
Old Jun 15, 2020 | 12:25 PM
Matthew V's Avatar
Default Help 02 suburban reduce engine power when i jumped it in the morning.
I also got the code p1518. I tried to drive it but wouldnt go past 20 mph. So than i waited 2 hours jumped it again and sounds good as it should. What could cause this? Bad battery low voltage? I added a subwoofer to it 2 days ago and it ran fine for awhile could the amp be the cause thanks.
Old Jun 16, 2020 | 12:20 AM
oilcanhenry's Avatar
OBD II code P1518 Is a faulty, damaged or intermittent Throttle Actuator Control (TAC) module. You'll need to address this issue or your vehicles will not run as intended.
Old Jun 16, 2020 | 6:02 AM
Matthew V's Avatar
so just replace the tac than?
Old Jun 17, 2020 | 4:30 PM
Yes, according to the code, it's gone bad.
Alaskan_Jesus
Nov 22, 2019 10:15 AM
David Bailey
Nov 1, 2013 2:32 PM
BW56
Jul 9, 2012 6:33 PM
steelhorse123
Dec 24, 2008 9:07 AM
08silveradonb
Mar 10, 2008 4:52 PM
