Help! 03 Burb misfire cylinder 6, system lean codes
Old Mar 23, 2025 | 5:15 PM
Brian’s Burb's Avatar
Default Help! 03 Burb misfire cylinder 6, system lean codes
Just had my cats and O2 sensors replaced so it could pass smog. On my way home from the smog I got the check engine light. Truck was running fine except at idle it runs rough. P0306 code was present. Checked the plug, it was sooty. I replaced all the plugs. Noticed the plugs on bank 2 were all black and sooty, bank 1 plugs looked normal. Fired it up and same problem, swapped wire and coil with cylinder 4, problem stayed in cylinder 6. Then I got the bank 2 system too lean code and the truck started spitting soot out of the tailpipes. Fuel pump is less than a year old. Changed the MAF sensor and checked for vacuum leaks. Any ideas of what to try next?
Old Mar 24, 2025 | 7:57 AM
rick1025's Avatar
O2 senser
GoatRoper97
Mar 30, 2024 4:15 PM
Frank Leal
Jul 11, 2017 4:05 PM
OtherCarASaab
Apr 15, 2015 8:36 PM
ksterrett
Jan 22, 2014 4:52 PM
gtfireman
Feb 3, 2011 5:18 PM
