Help with brakes
Old Sep 6, 2008 | 10:41 PM
clutch80nj's Avatar
Default Help with brakes
Hopefully you guys can help me,I have an 02 burb and just finished a cross country trip and just passed 100k miles. Now whenever I apply the brakes they start to pulse like antilocks do. I was thinking it was probably the rotors, any help you guys give would be much appreciated.
Thanks Bill
Old Sep 7, 2008 | 7:13 AM
jackyshaikh's Avatar
Default RE: Help with brakes
Your guess is right Bill. you have to reface the rotors,and relpace brake pads as well.You have to check LRO on brake lathe,if it is in specification go for cut,if not replace new one.hope this works for you.
Old Sep 7, 2008 | 11:57 AM
QBert's Avatar
abs sensors may need cleaning as well.
Old Sep 12, 2008 | 3:16 AM
95dirtyburban's Avatar
check that the wear is even. could also be a seized caliper. been there before.
Old Sep 24, 2008 | 10:08 AM
bmannchevy's Avatar
you might want to check the rotors for hot spots ( blackened areas on the surface with tiny cracks) if they are present, replace the rotors, don't even bother cutting them. 95dirtysuburban is probably right and this can caused the hot spots.
JRich_taco
Aug 31, 2013 12:16 AM
windpower79106
Jan 4, 2012 9:49 PM
Mille Racer 69
Dec 8, 2010 8:26 PM
VVG
Dec 15, 2006 12:30 AM
fryboy3k
Oct 9, 2006 7:06 PM
