help with hardwire radar install
Old Nov 28, 2010 | 2:10 PM
aubiexx's Avatar
Default help with hardwire radar install
I have hardwired radar detectors before with no issues and spent over an hour trying to figure this out.
I have tapped into the pink and black wires leading to the sunroof control. Checking via voltmeter it seems to read the same output as when testing from the cigarette lighter.
Can't get the unit to come on. I have tested 2 detectors and a portable DVD player. Both come on via cigarette lighter but not the wires to the sunroof.
Any ideas or someone with similar experience?
Old Nov 28, 2010 | 2:31 PM
DoubleO7's Avatar
Don't you want power only when ignition is on?
I am guessing you tapped into the sunroof wires upstream of the switch.
And the new detector does not have to be manually turned on every time via a momentary push-for-on button.
Just throwin some things out there.
Old Nov 29, 2010 | 5:41 PM
If your rearview mirror has all the buttons, self-dimming, etc then there's power there. Invisicord makes a cable to do that and tells you what colors to tap at the back of the mirror.
Old Nov 29, 2010 | 6:53 PM
aubiexx's Avatar
Default Thanks for the replies. I will try the invisicord and let you know results
I really am dumbfounded on this one since my connections seem to be solid and pulling power.
Old Nov 30, 2010 | 10:15 AM
Zed 71's Avatar
I made my own cord for ~$5 for my sports coupe. May make one for the Tahoe, and if I do I will post pics.
Old Dec 5, 2010 | 2:00 PM
aubiexx's Avatar
Default Update - I tapped the pink and black wires to the mirror - works
Really odd why I couldn't get it to pull from the sunroof power, but that's what it is. Hope it helps someone later.
scooter101
Jul 28, 2015 8:22 PM
gonavy1385
May 23, 2008 9:14 AM
jdkluck
Apr 12, 2007 1:17 PM
mlb2992
Feb 2, 2007 12:51 AM
jlenkows
Oct 20, 2006 11:50 AM
