Help identify this leak??
Old Oct 19, 2010 | 5:41 PM
antonovich's Avatar
Default Help identify this leak??
Does this look like evidence of the intake manifold gasket leaking? At idle my suburban has been a little rough, and i'm wondering if this could be it. From what i've read I'll have to pick up a mirror to see where the leak is coming from since its on the back side of the motor. If I get in that deep does anyone recommend a performance intake manifold that will still allow me to pass CT emissions?
[IMG][/IMG]
Old Oct 20, 2010 | 7:58 PM
what year and engine size? It would be my guess that it could be a connection to the intake manifold leak, or the manifold itself....
Old Oct 20, 2010 | 8:10 PM
MDTAHOE's Avatar
Professional Mechanic
Must be a 5.7 engine. That is exactly where the first signs (sometimes only)of the intake leak appear.
Old Oct 20, 2010 | 8:13 PM
MDTAHOE are you thinking its the quick connection leak or the manifold leak?
Old Oct 20, 2010 | 8:35 PM
MDTAHOE's Avatar
Manifold. Quick connect is more towards the front after they did away with TBI
Old Oct 20, 2010 | 10:30 PM
RacerX's Avatar
Why dont you pressure test the system and see? It may be a rotted hose or connection at the heater core or bypass hose. Could be a clogged/leaking/broken heater core also. Dont be so doom and gloom until you get concrete evidence.
Old Oct 21, 2010 | 7:01 AM
antonovich's Avatar
Default Thanks
Thanks for the advice guys. It ended up being a corroded/split heater hose connector on my 95 burb 5.7. Not too bad of a fix.
Old Oct 21, 2010 | 12:04 PM
RacerX's Avatar
Hahahaha! see, its pays not to be a Dr. Frankenstein before its time...
BrendonTW
Jul 16, 2013 3:12 PM
jeffs_62
Sep 10, 2009 8:42 PM
wylekaters
Oct 23, 2008 3:41 PM
Chimaera
Site Feedback
Jun 15, 2007 1:57 AM
Fiesty96
Jan 25, 2007 4:49 AM
