Help identifying part and where to order
Old Mar 26, 2019 | 6:24 PM
popoeye7's Avatar
Default Help identifying part and where to order
The piece coming off the pressure port of
the power steering pump of a 99 k2500 burb with 7.4. Any help of what it is called so I can try find where to order would be greatly appreciated. None of the local part stores
have a clue!
Old Mar 28, 2019 | 3:01 PM
popoeye7's Avatar
Default Found the answer
So that is the Electronic Varible Orfice. It was suppose to help control pressure base on speed. Didn’t work well so they discontinued them. If you have a model that used it you have to make sure you order a pump w/ resivoir that comes with the EVO bypass pipe. Hopefully this helps someone before they buy the wrong pump. Good luck.
[/QUOTE]
