Help! My Suburban cuts off while driving
Hey guys, heres the deal. I have a 93 Suburban and about a week ago it cut off on me while driving. started right up. did it again the next day and the next. Now I have to wait for about 20 seconds or so for it to start back up. Other than that it runs fine. No skips,misses or anything. The fuel pump kicks in with no problems. I had the ignition module tested and its fine. someone told me it could be the pick up coil but I thought that if that was the case, it wouldnt start up at all. Then someone mentioned it could be the ignition coil. any ideas?
well, changed the fuel pump,filter, and fuel pump relay. Changed the ignition coil and the ignition module was tested good. Truck still starts up fine and thens cuts off while driving later on. Sometimes she just turns over and about 30-60 seconds later, she starts back up. Can someone please give me some advice.
Hey Im new here, but I saw your post and found it very helpful as I have a 94 suburban that is doing the same thing. But I do have a question did your Battery light start to flash on and off as well cuz that is what mine is starting to do now as well as cutting off while driving.
cut off one night on me, started right back up. Did it the next day, and the next. 3rd day, it turned over longer than normal and then started back up. Got worse on day 5. At first, I thought it only did it while slowing down at stop lights ect. but then i could be driving 40mph and up and it would just shut down like I had pulled the battery cable off or something. Dash lights came on like the brake ,engine,etc. Nothin ever came on while driving though. engine light never came on so I could use a code reader to see what the problem was. Anyways, I took the ignition module to Autozone and advance Auto parts and they both tested it to be fine. Guess it showed good while it wasnt hot. changed the module and no problems since.If your battery light is flashing while you drive, you may want to check alternator,battery,etc. Could be a voltage problem.
