Help with p0449 & p0455 codes
Old Jun 24, 2014 | 8:02 PM
  #181
4x4tx's Avatar
Does anyone have updated part numbers or or links for this fix? What us the minimum that needs to be replaced to clear the codes?
Old Jun 24, 2014 | 8:13 PM
  #182
titantn24's Avatar
ACDelco 20995472 Evaporative Emission
ACDelco 19257603 Evaporative Emission Canister Valve Solenoid Jumper Wiring Harness Assembly
Old Jun 24, 2014 | 8:15 PM
  #183
titantn24's Avatar
Sorry, hit send too fast...
ACDelco 20995472 Evaporative Emission Canister Ventilator Assembly
Old Jun 24, 2014 | 8:25 PM
  #184
titantn24's Avatar
http://www.amazon.com/gp/aw/d/B004O8...3659398&sr=8-1
http://www.amazon.com/gp/aw/s/ref=is...ness+Assembly+
Old Jun 25, 2014 | 11:05 AM
  #185
4x4tx's Avatar
Thanks man, I guess this is the new style right since it has the updated harness?
Old Jun 25, 2014 | 11:25 AM
  #186
titantn24's Avatar
Yes. I just put both these parts on my '07 Suburban LTZ back in February. Wasn't too bad of a job. Drop the spare tire first. Won't be able to do it with that in the way. I had to reset the code with my reader afterwards, but the code never came back. Good luck.
Old Jun 25, 2014 | 2:18 PM
  #187
DrumMum's Avatar
Default Update from last year
So, anyways......I had to take my Suburban to a real mechanic for repair. Guess what? It was like a $2.00 Fuse.
The dealer I bought it from had to fix a problem before I would purchase....so they ended up eating a $500.00 repair.
After they "fixed" my original problem, I had the issue with the p0449 code. The problem wasn't any of the purge valves, solenoid valves, or gas cap.....it was a fuse!!! Funny, the vehicle worked fine and "check engine" never came on until AFTER the Stealership "fixed" my original problem.
just thought i'd update it....a year later! lol
Old Nov 6, 2014 | 2:58 PM
  #188
assault life's Avatar
I kow this is an old post but what fuse was the problem as I'm just now running in to this problem with both my 10 Avy and 07 Suburban.
Old Nov 11, 2014 | 10:33 AM
  #189
skmpmm2002's Avatar
Default Code P0455
I am also getting a P0455 code BUT..... my issue is that i cannot fill the tank at more than a snails pace.
I could care less about the emissions issue (no emissions checks in Florida)
I am guessingthat its not the gas cap. I tried replacing the Canister vent valve solenoid already with part #
Duralast/Canister Vent Valve Solenoid PV485
OK so......that did not work....now what? any help is appreciated.
Old Mar 17, 2016 | 10:03 AM
  #190
nickn's Avatar
Default p0455
I am also getting the code p0455 on my 2007 chevy Silverado 2500hd, 6.0, 4x4 new body style. I have already replaced the solenoid located on the back of the gas tank, upon further inspection I followed the corrugated vent line from the solenoid towards the front of the truck and found another rectangle shaped canister on the end of the hose. it was just hanging freely under my truck(not attached to the intake manifold like everything I have found says it should be), I can not find anywhere where this should attach to the intake manifold like it says it should. Can anyone help me with pictures or any other way to find where this attaches to the motor. it is the part on the left in the pic below. Thanks NIck
Henry St-Pierre
Aug 27, 2015 8:58 PM
jf7623
Nov 11, 2012 11:28 PM
Ecssound
Jan 23, 2012 5:19 PM
EddieClassic07
Dec 11, 2011 1:53 PM
XiBowhunter
Mar 22, 2010 12:29 PM
