help to remove brake power booster
Old May 17, 2009 | 12:20 PM
tampc's Avatar
Exclamation help to remove brake power booster
My 95 Chevy Sub. has 127K miles on it, when I sttep on the brake there sond like linking vacuum noise, and the brake does not have power to slow down I have to puss the pedal hard to slow down and some it allmost stoped the van.
Did removed master cylinder - removed 4 bold of brake booster from in side firewall and is it a tip or howto remove the brake booster out from brake pedal I has been try all moning but not able to remove the retainer out from the pin.
Please any onece has been work on the 95 chevy sub. please help
Thank your
Old May 18, 2009 | 9:20 PM
timdogg1313's Avatar
I used a small screwdriver to remove the pin by prying it up. Took a little work, but finally got it removed. I didn't purchase a new one so if you don't plan on it either try and keep it in tack. Also, had a time trying to get the old/new rod back on the pedal bracket, so maybe someone can chime in and give a tip on how to remove/reinstall.
Old May 22, 2009 | 11:29 AM
SabrToothSqrl's Avatar
Default brakes
well, you kinda suck it up and do it.. i did one on my 95 tahoe... put the seat all the way back, the wheel all the way up and lay on your back under the dash... its fun!
Engineerguy
Nov 19, 2014 10:10 PM
kansfan48
Jan 19, 2014 11:51 AM
qzack1
Aug 28, 2011 12:50 PM
bgb
Aug 25, 2011 11:14 AM
