help service 4wd light...cut a wire now what?
Old Jul 17, 2011 | 4:50 PM
buffalobigj's Avatar
Question help service 4wd light...cut a wire now what?
So I was putting an amp and sub into my 02 burb and cut a hole in the gromment on the upper firewall drivers side to run the power wire through. When doing so I somehow cut a black/white stripe wire. I didn't notice it until I started the vehicle and saw the service 4wd light come on. I immediately shut the truck down and located the cut wire. I spliced it back together and soldered and taped it. However I still have the service 4wd light on and no lights on the 4wd switch. I checked the atc fuse under the hood and the 4wd fuse inside both were OK.
At this point I don't know what to try, could I have killed the switch when I cut the wire? How can I test to see if its getting power (what wire)? This has me worried, is it still OK to drive this week to work? Any help for a newbie to the group is appreciated. I've only had this truck a few weeks...
Thanks! Jeff
bossman696
Jul 19, 2010 11:17 AM
isrblue
Jun 15, 2010 6:24 PM
leevil
Feb 1, 2010 12:11 AM
waller2003
Oct 19, 2009 9:49 PM
DianaT
Nov 29, 2007 12:12 AM
