High Idle, high RPM in neutral while at speed
Old Oct 6, 2020 | 10:23 AM
  #21
rob t's Avatar
I have a 07 Acadia that i cleaned the throttle body on and now it will idle great for about 20 minutes then go to 3000 rpm and stay.
i have done the reset numerous times with the same outcome. I lost!
Old Oct 6, 2020 | 11:51 AM
  #22
check for vacuum leaks. Listen for a hiss or spray around the intake with a plastic safe flammable aerosol like starter fluid.
Other than that, the computer needs to be read by an OBD scan tool. Requested idle, ECT, MAF... things like that.
Old Oct 11, 2020 | 1:15 PM
  #23
PNW NBS Z71's Avatar
IMO only, you were on the right path with looking at the MAF but I would never blow air through it. There is a MAF cleaner with instructions that you should be able to get at any parts store. Buy it and follow the directions. There is also a cleaner for the MAP sensor, may be the saame cleaner as the MAF and that should be done at the same time. "Maintenance pays and breakdowns cost" is what my dad always said and I am a firm believer in maintenance and you are too because you were cleaning the throttle body and plate.
Old Dec 25, 2020 | 11:34 PM
  #24
Jimmer Thompson's Avatar
Originally Posted by 73shark
The BATF is going to come after you for running an illegal still.
alka
Astro
Mar 29, 2015 8:08 PM
philm
Jan 7, 2015 11:03 AM
Wigz14
Traverse
Sep 7, 2014 7:14 PM
85fordyota
Jun 27, 2013 11:26 PM
Jing
Apr 15, 2011 4:03 PM
