High oil pressure
Old Nov 4, 2014 | 12:52 PM
scott81425's Avatar
Default High oil pressure
Afternoon all-
In my 07 burb, which I've had about 5 months now, I notice my oil pressure is running a little high after my most recent oil change. Not alarmingly high, but to the right of center. Comes back closer to center after it runs for a while but never really settles in the middle. Is this normal? I seem to recall it being in the middle before but don't recall for sure. Anyone?
Old Nov 4, 2014 | 1:39 PM
scott81425's Avatar
I'm not sure how to post a pic- but at startup its almost over to 60 psi. I'd say 80% of the way from 40-60. After warming up I'd say its 33% of the way from 40-60.
Old Nov 4, 2014 | 2:38 PM
scott81425's Avatar
Every now and then an impulse purchase comes in handy. I plugged in my Bluetooth obdii reader to get actual numbers. Warm engine idle is about 43-45 psi oil pressure. Revving up to 3k rpm gets me to about 57-58 psi. Holds steady.
Old Nov 5, 2014 | 11:17 AM
Are you using the recommended 5w-30?
Correct filter?
How many miles are on the engine?
Has any rebuild work occurred?
Old Nov 5, 2014 | 5:53 PM
scott81425's Avatar
Correct filter?
No rebuild, 115k. 5w-30 max life. And a Napa gold filter. I really watched it today. Sits right at that 45 mark after it warms up. When I cruise out on the highway it gets closer to that 58 mark. I'm guessing this isn't normal?
Old Nov 5, 2014 | 8:27 PM
67Motorcat's Avatar
Quite normal actually.....as ambient temperatures become colder going into the fall,observed oil pressures can go up.
Engine seems healthy for over 100K miles.
Old Nov 7, 2014 | 10:47 AM
I agree that colder temps will cause a higher reading, but its also possible that the sensor is just off, you could always replace it for the sanity check...
outdoordb
Aug 19, 2020 3:26 AM
not_a_car_dude
Sep 15, 2013 7:41 PM
WorkerB
May 29, 2008 2:24 AM
ot01314
Apr 14, 2008 7:27 AM
Gymnutz
Mar 25, 2007 5:45 PM
