Old August 6th, 2015, 2:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
How to install OEM Nav on 2007 Tahoe
Old April 28th, 2007, 8:20 PM
  #201
jlenkows's Avatar
Default RE: How to install OEM Nav on 2007 Tahoe
Why not go to the dealer and ask them if you could try one of their map DVDs in your radio. It could just be a bad disk...
Old April 29th, 2007, 9:57 PM
  #202
gdhodge's Avatar
In regards to those who havehad a problem with voice recognition. Mine was terrible, would only get my commands 1 out of 15 times that I tried. I pull the radio again andgiggled the wires on the 2 pin connectors , form JP Customs, that go into the C1 connector. I had a terrible time getting those little suckers in anyway. After giggling the wires, the voice command worked flawless.I taped the2 wires tight around the other wires in the harness and put the radio back in. Now both my wife and I can get every command to work the first time we say it. Just thought this might be something for you guys who are having problems to maybe check.
Old May 5th, 2007, 1:59 PM
  #203
mkinder's Avatar
ORIGINAL: biglg
You are using a back up disc of your own "original" dvd map disc, RIGHT?
I have no idea, just had to put that out there!
I have the orignal nav DVD... Would anyone be willing to hook a brother up witha "backup copy"
of the new Data Disc 15934919u? Happy to supply media andor postage...[8D]
Thanks guys,
Matt
Old May 8th, 2007, 3:17 PM
  #204
cruzsuburban's Avatar
Default RE: How to install OEM Nav on 2007 Suburban
I have a 2007 chevy suburban with Bose CD/DVD/XM rear entertaimenr flip down monitor and Iwould like to install the factory NAVIGATION SYSTEM. I found some in the Ebay and Ineed some help to deterninate wich is the one that it will fit my truck. Or somebody that had installed this unit in a suburban that was build on early 2006, the dealer number for those trucks is diferent for the ones build on the late 2006.
Old May 10th, 2007, 12:23 AM
  #205
ash0479's Avatar
Allright I am completely confused, I have a 2007 Denali, brand spanking new, my Nav is on the way, no Rear Seat DVD so I need GM Part number ending in 103 as far as the head unit, I also have the Nav Antenna and MAP CD...Where can I get the JP Custom Connectors and can someone give me the part numbers, I just want to ensure I have everything before I start tearing apart the new car, thanks again in advance, the information would be greatly appreciated!
Andy
Old May 10th, 2007, 7:41 AM
  #206
genestoy's Avatar
Here is their website http://www.jpcustoms.com/store/customer/home.php the part is not listed there. Talk to Brian and tell him what you are doing and he knows which part you need. If you have the Onstar be sure to tell him you need that connector also. Their phone number is 281-533-9900
Old May 14th, 2007, 1:03 PM
  #207
tahoelover26's Avatar
Hello I purchased a dvd navigation unlocker from ebay It works great and got it cheap the item # is 150115773206 please let me know if there anything cheaper than that so i can purchase another one I got mine for 245 with shipping the ebay store name is gnlshops.
  #208
Old May 14th, 2007, 2:01 PM
  #209
hardtymz's Avatar
Is this info good for the 07 Suburban. I have an lt3 with onstar rear entertainment dvd ect. Do I have to get a new gps antenna or will the onstar sat antenna work?
Old May 14th, 2007, 3:18 PM
  #210
Quick Reply: How to install OEM Nav on 2007 Tahoe
