Old Aug 6, 2015, 2:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
How to install OEM Nav on 2007 Tahoe
Old Feb 11, 2010 | 7:46 AM
  #501
rsrlegends's Avatar
Here's a link to drawing that may help find the correct wire...
https://chevroletforum.com/forum/sho...5130#post85130
Old Feb 11, 2010 | 8:43 AM
  #502
biglg's Avatar
Thank you very much. I tapped in to a green/white wire in that block but it seemed it was wire or two higher on the junnction. Is there only one green white wire in that connector?
I will look when I get home however I am sure I went to the correct one. Thanks for the information.
Old Feb 11, 2010 | 8:57 AM
  #503
RayRay's Avatar
The orientation of the picture may be different than the way you pulled your box out. I had a hard time with using a vampire tap and ended up cutting the grn/wht and using a butt splice. I twisted the VSS wire from the radio around one end of the grn/wht wire I cut and crimped them to one end of the butt splice. Then crimped the other end and it made a strong connection.
Old Feb 11, 2010 | 12:53 PM
  #504
biglg's Avatar
The orientation of the picture is actually the same. I will have to look again tonight when I get home. At least I am in the right connector and not the top one with the green/white wire. Thanks again.
Old Feb 11, 2010 | 4:59 PM
  #505
Highly recommend soldering vs crimp-ons.
biglg: Did the DVD arrive yet?
Old Feb 12, 2010 | 7:04 AM
  #506
rsrlegends's Avatar
You are right, I soldered mine as the crimp tap did not work real well...
Old Feb 19, 2010 | 11:33 AM
  #507
ps1588's Avatar
Default 09 tahoe LS nav and Camera install
i have a 09 tahoe LS i purchased at nav w/ dvd capabilities. i want to install it, but im scared to start cuz im worried its gonna be a nightmare. my hoe does have a OEM reverse cam in the rear-view mirror, so i need to know how i can redirct the image to the nav instead. i would also like to know if anyone has any pre-warnings for installing nav into a LS without bose system. thanks
Old Feb 28, 2010 | 8:43 AM
  #508
Tahoe2506's Avatar
I just installed a the nav system on my 2007 Tahoe lt. The truck is not equipted with rear camera or dvd. i used the part number 15882767. I installe the nav antena, radio antena, and the two plugs from my truck, just this system comes with four plugs. i assume that the other teo plugs are for rear dvd and camera. The unit says theft lock. A local gm dealer tech tried to unlock it, but he says my truck was not accepting the program. He also said this was his first upgrade, so i think he did not know how to program the unit. Can someone let me know if am on the right track here.
Old Mar 14, 2010 | 7:28 PM
  #509
mkinder's Avatar
I have a 07 Hoe and installed the NAVI/DVD HU along with amp kit and GM pick.
All is working great...
I also bought the factory rear DVD unit. Along with that the "under headliner" bracket.
No problems there, however the harness from rear DVD unit to Front HU is what i am fighting.
I bought the plugs for the rear DVD unit, however the HU has a (C-13 i think its call, same plug as the speed senosr).
It is my guess that the rear DVD unit has a harnes and perhaps goes to the backup camera controller box located under the pass seat (which i dont have). ??? maybe???
Any idea about the connection from Rear DVD unit to the HU?
Thanks a ton, you will see i posted about the non bose install to try to help others, but this rear DVD unit has me stumped for now.
https://chevroletforum.com/forum/show...&postcount=249
Thanks for any help.
mkinder
mkinder
Old Mar 15, 2010 | 5:36 PM
  #510
Tahoe2506's Avatar
Smile
I have an 07 tahoe and i installed the factory nav and i cannot get the radio ro program at tried at two dealers. The radio that i insatlled is for tha tahoe and i also have the bose system. can someone help ?
