How much oil does a 2018 Suburban go through?
Old Aug 28, 2019 | 8:44 PM
WyleyPilot15's Avatar
Default How much oil does a 2018 Suburban go through?
Hi All - just completed a 3k cross-country drive in 2018 Suburban and used about 62% of the oil in the vehicle which equates to my math of just under 5 quarts. No oil leak found on the pavement etc.
Is that normal? Have to drive it back across country and looks like need to find a place to change it mid-drive.
Thanks all
Old Aug 28, 2019 | 10:24 PM
are you referring to oil life percentage or you had to add 5 quarts of oil in 3000km due to a low oil level?
8 quarts is the capacity for the system and you added 5...seems high. Gm had a tsb for the previous gen trucks and allowed 2 quarts per 3000miles as allowable.
Old Aug 28, 2019 | 10:42 PM
was referring to oil life. went through 62% of "oil life" on the drive.
Old Aug 29, 2019 | 7:00 PM
then its normal. I run full synthetic and I change at a 6000 kilometer interval which is the severe service interval. when you have, afm, cam phasers that are oil controlled with small oil screens...don't run extended oil change intervals.
Old Aug 29, 2019 | 8:11 PM
Okay - great to know then, many thanks.
bues0022
Aug 6, 2018 12:55 PM
EITANEE911
Jul 24, 2018 7:45 AM
One1014
May 17, 2018 7:45 AM
Goatkin42
Jan 17, 2018 9:58 AM
