How to remove plastic grill mesh
Old Mar 28, 2011 | 12:03 PM
magician's Avatar
Default How to remove plastic grill mesh
I'm looking to replace my plastic grill mesh with the stainless wire, anybody know how to remove it or where I can find detailed instructions, without destroying it?
Old Mar 28, 2011 | 6:30 PM
It appears that if you remove the frame, you'll have access to the backside of the grill insert which has tabs that appear to hold it in. The tricky part would seem to be how to release/bend the tabs enuf to allow the insert to be removed. Maybe several friends working together. Bear in mind that this is conjecture as I've never done it, just an observation I made when I was looking for a billet grill. Finally went w/ a bolt-over which worked fine as the early '07s didn't have the chrome inserts.
Old Mar 29, 2011 | 4:08 PM
magician's Avatar
While home with a sick kid today I got a chance to take a look and it seems there are the tabs you speak of but I dont see how the chrome frame would come out without the black mesh?? I could be wrong but its the way it looks to me... I found a GM part number for the Chrome SS grille inserts and from the pictures they just go in from behind the grill so I was assuming the black mesh would come out the same way???
If its like what I had on my Titan I may just have to go with an insert....
Old Mar 29, 2011 | 5:07 PM
I can pull out my Chrome mesh but I have not taken the chrome ring out...it seems that it may be a part of the front fascia...
Old Mar 29, 2011 | 8:11 PM
2007 Chevrolet Tahoe - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Body Hardware and Trim | Exterior Trim | Repair Instructions | Document ID: 1698643
Fascia Grille Replacement (Suburban, Tahoe)
Callout
Component Name
Preliminary Procedure
Remove the fascia. Refer to Front Bumper Fascia Replacement .
Grille Screws
Notice: Refer to Fastener Notice in the Preface section.
Tighten
9 N·m (80 lb in)
Grille Clips
Grille Assembly
Tip
Release the tabs securing the grille.
2007 Chevrolet Tahoe - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Body Hardware and Trim | Exterior Trim | Repair Instructions | Document ID: 1758502
Front Bumper Fascia Replacement/removal (Tahoe)
Callout
Component Name
Remove the front wheelhouse liners. Refer to Front Wheelhouse Liner Replacement - Left Side and Front Wheelhouse Liner Replacement - Right Side .
Front Fender Bracket Bolt (Qty: 4)
Tighten
7 N·m (62 lb in)
Front Fascia To Impact Bar Brace Bolt (Qty: 2)
Tighten
10 N·m (89 lb in)
Front Fascia To Radiator Core Support Bolt (Qty: 6)
Tighten
6 N·m (53 lb in)
Front Fascia
Procedure
Disconnect any electrical connector.
Transfer parts as needed.
© 2011 General Motors Corporation. All rights reserved.
Attached Thumbnails How to remove plastic grill mesh-capture1.jpg   How to remove plastic grill mesh-capture2.jpg
RUSAN
Apr 17, 2012 3:32 PM
Flipg8tor
May 6, 2011 7:13 PM
Flipg8tor
Mar 24, 2011 1:23 PM
jazejeff
Mar 23, 2008 8:38 AM
2Step
Nov 13, 2007 5:04 PM
