Old Jul 24, 2015, 4:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
I cleaned my TB now high revs @ idle
Old Apr 21, 2018 | 2:07 PM
  #41
mfarooqgul's Avatar
A week before, the temperature gauge was rising 1 point up and after 30 seconds its come down to normal.
I searched on google and then replaced the thermostat valve and coolant also. After that problem solved.
But yesterday it happened again, Could not understand, why it is happening after changing the coolant and thermostat valve.....
what about temperature sensor? can be reason??
These all things are happening after the throttle cleaning.
Old Apr 29, 2018 | 2:19 PM
  #42
Bassman1068's Avatar
Originally Posted by RJK
No Codes, it seems fine while driving or in gear, just in park/Neutral is where I get idle @ 2000rpm Ill drive it some more and see if it goes away.
I have read where other had the same issue and just driving fixed it.
Thanks
Yeah, keep driving it. Did mine 3 nights ago and have driven it quite a bit since. It has gotten a lot better but I have read that some people have had to drive theirs a couple hundred miles before returning to "normal" idle behavior. Like I said, mine has improved a great deal, yet, now & then upon start rpms will jump up but when I shut off and restart in neutral the shift into Drive is much smoother/ not a hard shift. Driving it's fine. My TB was so gunked up with carbon the truck would stall when stopping or slowing to make a turn. Cleaning straightened that issue out
Old Aug 26, 2018 | 8:36 PM
  #43
Ted8755's Avatar
Default High idle 1800 rpms
I have 2007 Dodge Durango tried all of these steps but none worked. Replaced pcv valve, air idle control valve and throttle position sensor. Still have it at 1800 rpms. Please help.
Old Sep 16, 2018 | 5:48 PM
  #44
Papa J's Avatar
Default Brake push 3x works!!!
Had same issue with 2009 GMC truck 5.3l
after reading multiple comments & stories. Came across the excerpt
Disconnect battery and push brake pedal 3x, sceptical as I am, I felt like a fool disconnecting the battery then pushing the brakes 3x. Thinking next I would be jumping through a hoop of fire. Surprised when I started the truck, it did just as instructor said. Idle jumped up to 1800 for a few seconds then dropped back down as it said.
Please forgive the lengthy statement.. but remember
KISS keep it simple stupid
Old Sep 17, 2018 | 9:40 AM
  #45
Thanks for following up , and Welcome to the forum !
Old May 13, 2019 | 6:52 PM
  #46
Lou84's Avatar
Default Thanks
Originally Posted by Marklar24_7
Dont waste your time on a drive cycle. Ive had a low success rate w that. Simply disconnect negative battery cable and pump brake pedal 3x. Reconnect battery and your idle should jump to 1800, then settle down to 900-1000 rpm in park in a matter of seconds. THIS WORKS!
Awesome fix. Thank you 😊
Old Jun 4, 2019 | 3:21 PM
  #47
Michael Cheek's Avatar
Default Pump Brakes 3X
After days of reading multiple threads, this seems sensible to try on my 2007 Pathfinder, no offense. My last vehicle was a Yukon Denali. Loved it til the transfer case stopped loving me.
Old Nov 4, 2019 | 6:48 PM
  #48
Jesse Clark's Avatar
Default Revs @ 2000 only in park and neutral
Originally Posted by Rippinghawk
Ok,
I had to clean the TB. I was getting the stuttering and rough engine at the 25-40 mph zones and the stabilitrack warning a few times.
I took the TB off the vehicle, removed the electronics module. and very carefully with a brush and dry cleaning solvent cleaned the daylights out of it. It is pretty. I was careful to keep the solvent out of the stepper motor assembly and the two sensors on the unit.
I now have the high idle issue, that I did not have before.
I tried the tech service with the tech bulletin 1 update, that did not work. Going to drive it a bunch this evening to see what I can get out of it.
Edit #1 Taking the negative battery lead off the vehicle (not smart anyway!) and pumping the brakes 3 times did not resolve the high idle. I will state that I did this while the car was off and not running. This resulted in a 4K RPM on the next crank of the vehicle however.
Edit #2 I disconnected the battery completely and shorted the cables to each other. I then cycled the key on and off a few times. I left the battery off the system for about 4 hours while I was working on other things. No change. 1800 RPM.
After cleaning my throttle body on my 07 Avalanche I had the high RPM rev at 2000 only in park. I tried all the relearn procedures and drove many miles waiting for the idle to learn. Never got better until I tried the disconnect negative battery and pump brake pedal (3) times. This worked immediately!!!!!!!
Thank you all for all your support!!
Old Jan 25, 2020 | 3:59 PM
  #49
Zizzo Marcus's Avatar
Default Nevermind that snake oil trick is crap!
Nevermind this **** doesnt work you will have to have access to a scan tool! The truck started doing the high idle again and the trick didnt work a second time screw these modern computers!!!!!
Originally Posted by zizzo marcus
so got a 2010 4.8 1500 silvarado here. I was fixing to have a heart attack because after doing the thermostat, cleaning the engine to find a leak, and cleaning the throttle body due to a tps performance code p0121 i was getting, the truck revved right up to 2k. I watched a youtube video where a guy said never to f*** with the throttle body because the only way to get it to stop is with an expensive scan tool to force the computer to relearn the idle. But this right here worked for me! No $5000 scan tool needed! You saved me! Thank you! After this scare i think ima buy a proper scan tool anyway! Anyone know if the harbor freight $999 scan tool will performe advanced stuff like an idle relearn?!
Old Oct 23, 2020 | 3:33 PM
  #50
Bryan Boswell's Avatar
Default What kind of vehicle do you have? I've been trying to find the IAC on my 2007 chevy s
What kind of vehicle do you have? I've been trying to find the IAC on my 2007 chevy suburban
