Old Jul 24, 2015, 4:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
I cleaned my TB now high revs @ idle
Old Oct 23, 2020 | 4:47 PM
  #51
PNW NBS Z71's Avatar
Originally Posted by Bryan Boswell
What kind of vehicle do you have? I've been trying to find the IAC on my 2007 chevy suburban
Welcome to the forum from Oregon.
The idle air control valve is part of the throttle body assembly and is likely riveted to it. In that case you will need to either replace the throttle body unit or drill out the rivets and see if you can find a separate IAC valve that you can attach to your throttle body. It looks like this:
https://www.rockauto.com/en/moreinfo...433403&jsn=922
Old Oct 23, 2020 | 8:05 PM
  #52
2007 drive by wire don't use iac. they control idle by moving the throttle valve.
Old Mar 4, 2021 | 4:22 PM
  #53
Shepherd Shannon's Avatar
Originally Posted by Marklar24_7
Dont waste your time on a drive cycle. Ive had a low success rate w that. Simply disconnect negative battery cable and pump brake pedal 3x. Reconnect battery and your idle should jump to 1800, then settle down to 900-1000 rpm in park in a matter of seconds. THIS WORKS!
It worked great!!
red suburban
May 6, 2023 12:52 PM
in2pro
Dec 25, 2020 11:34 PM
jwjr
Jul 9, 2015 5:09 PM
jlutty3
Mar 2, 2015 9:33 PM
kober
Sep 4, 2009 2:39 PM
