I have a part issue that doesn't make sense.
Old Nov 9, 2006 | 7:26 PM
digdug's Avatar
Default I have a part issue that doesn't make sense.
I just recieved my new splash gaurds in the mail and I have a issue. They don't seem to fit.
When I look inside the guard itself it shows what I believe to be a prt # of 19131701 for one of the fronts (w/ running boards) and #19131702 for the other front.
Then I see part #19131707 on one of the rears and #19131708 on the other.
However this isn't what I ordered. On the directions that came with the rears it shows a part # 19131712 and for the fronts #19131703.
I tried putting them on and they seem close to fitting but they don't on the rear and the front doesn't even seem close. I ordered them through Chevy Parts Mall and their website is conveniently down.
Any ideas as to what could be going on. I've got a suspiscion that what I have is not correct.
~digdug
Old Nov 9, 2006 | 9:41 PM
tahoe07's Avatar
Default RE: I have a part issue that doesn't make sense.
I got mine at the dealer Monday. I put them on and took them right off! I can't stand mud flaps and they are as bad as any. I'll put them on when the snow flies and the salt goes down.
dealer part numbers
17802157 front w boards
17802159 rear
Front w boards
19131701 printed inside pass.
19131702 printed inside driver
19131703 is # paperwork
Rear
19131707 inside rr
19131708inside lr
19131712 is # paperwork
Old Nov 9, 2006 | 11:11 PM
biglg's Avatar
I was kind of shocked when I put my molded flaps on too. The rears didnt seem to fit perfectly either, the holes seemed to be higher than I could get the flap holes. However, after some serious cussing I got them on.
I was also shocked to find out that I had to drill holes in the front running boards to mount them, I thought they were no drill? At least that is what I was told!
Old Nov 9, 2006 | 11:17 PM
digdug's Avatar
That's what I was afraid of. When I try to put that slit in the mudflap around the pinchweld behind the wheelwell it wants to bend that pinchweld down and even then I can't get the holes to line up. I'm going to send them back. For OEM parts they absolutely fit like ****.
~digdug
Old Nov 9, 2006 | 11:22 PM
I only put the rears on but they fit like a glove.
Old Nov 9, 2006 | 11:35 PM
biglg's Avatar
Did anyone else put on the fronts and drill the holes.
Has anyone had them on for a length of time and removed them? Do you think it will rub the paint or caust black marks on my white paint, or any color paint?
Old Nov 9, 2006 | 11:41 PM
schorner's Avatar
I drilled the holes in mine, but haven't taken them off. My rear flaps fit nicely. The front ones I had to trim a little where they went over the running board. It wasn't fitting tight against the body.
Old Nov 9, 2006 | 11:50 PM
digdug's Avatar
Does anybody else know what I'm talking about with placing that groove over the pinchweld on the rear mudflap? It seems like it wants to bend down when I try to push up the top of the mudflap to align the holes.
Old Nov 9, 2006 | 11:55 PM
schorner's Avatar
Mine lined up perfectly. You are talking about that hook that hooks onto the bottom of the bumber?
Old Nov 9, 2006 | 11:57 PM
digdug's Avatar
Yeah that's it. Seems like I had to use aloto of force. I would slide that groove over the pinchweld and then move the top towards the holes. As I did this it started to bend the pinchweld down.
