Intake Gasket or head Gasket?
Old Oct 14, 2011 | 2:43 PM
Dads Toy's Avatar
Default Intake Gasket or head Gasket?
I have a 1999 Suburban with a 5.7L V8 (144,000). Leaks no oil, uses no oil, has no coolant leaks. Problem I have is cyclinders 6 and 4 have only 10psi on a compressing test. It starts on a dime with no problems and idles with a bad miss. If you go up a small hill or load the engine it knocks bad. Just wonder if a bad intake Gasket could cuase this or is it more leading to a head gasket repair? Spark plugs are dry and have no oil etc, clean burning plugs. There is no oil in the coolant, oil is fine.
Old Oct 14, 2011 | 3:44 PM
kevinkpk's Avatar
Any blowby in the crankcase?
Old Oct 14, 2011 | 4:57 PM
Dads Toy's Avatar
How can you tell?
Old Oct 14, 2011 | 5:00 PM
kevinkpk's Avatar
Pull the oil fill cap off, is it excessive? That is blowing oil mist heavily out the oil fill port.
Old Oct 14, 2011 | 11:00 PM
MDTAHOE's Avatar
Professional Mechanic
Blown intake gasket will not cause low compression. You could be looking at a head problem but that would be rare on a 5.7. Try adding some oil to the cylinder spin it over a few times and see if compression go up. It could be possible that the fuel injection unit has failed and washed out the cylinders
Old Oct 15, 2011 | 8:00 AM
maxxman04's Avatar
i've had two vortecs that blew the seal between cylinders. cylinders 4 and 6 as well as 3 and 5 have the exhaust valves side by side. this is where i've seen the head gasket fail, directly between these cylinders. the water jackets stay sealed, so no coolant leaks, but compression is lost.
Old Oct 18, 2011 | 11:06 AM
Rings and valves can also cause low compression. If oil in the cylinder doesn't help then try hooking an air line to the cylinder and listen in the intake and tail pipe for air hiss.
Old Oct 20, 2011 | 8:05 AM
Dads Toy's Avatar
That's a great Idea. I can use my compression tester since it already has an air fitting on it. I just wonder if a fuel injector can pop out?
Old Oct 20, 2011 | 5:55 PM
maxxman04's Avatar
no, they locked in pretty good.
Old Oct 21, 2011 | 6:54 AM
MDTAHOE's Avatar
On the 5.7 with CPI injection the fuel injectors can pop out. They snap into a small hole with a plastic tab. Over time the plastic tab breaks off an d injector pops up away frao the hole.
Enraged_Bacon
Mar 10, 2014 10:35 PM
HeavyChevyTom
Jul 25, 2012 9:23 AM
DOBERDEWD
Dec 11, 2011 11:35 PM
NovaProject
Nov 6, 2010 12:35 PM
gulfcoastjoe
May 4, 2008 12:38 PM
