Interior light problem, 99 Tahoe
Old Nov 6, 2006 | 9:32 PM
Christina's Avatar
Default Interior light problem, 99 Tahoe
Hello... I am having an interior light problem on my 99 Tahoe, hopefully someone has an idea what's going on and can give me some pointers.
For no particular reason, the courtesy lights (all the lights that come on when you open the door...at feet, on doors, dome and rear dome) flicker. I can be driving down the road and they just flicker on and off. Also, I have been out of the truck for a while and have gone back out and the lights are on. Obviously, I have had to replace the battery once.
I can't seem to replicate the problem, by going over rough patches or shaking the doors. I hear a click when the lights come on near the headlight switch, but can't seem to see what's going on...while driving! [>:] I'm wondering if it could be the delay timer, any ideas if this is a dealer part?
Or is the thing just possessed?
Thanks!
Old Nov 6, 2006 | 9:42 PM
tahoe07's Avatar
Default RE: Interior light problem, 99 Tahoe
Could it be the switch in one of the door jams? If it is flickering and it's all of the lights that come on when the door is open, I would start there.
If it's not there try the switch for the interior light levels, the one you use to dim or brighten the dash lights. If you turn it all the way those lights come on right?
Old Nov 6, 2006 | 10:37 PM
Christina's Avatar
Right, it's those lights that flicker.
Thanks for your help, I am beginng to think my dream car may not be so dreamy .
Old Nov 7, 2006 | 12:48 AM
It's possible that one of the door switch wires has worn thru the insulation and intermittently touches body metal (ground). The way GM switches the lites on is by taking the ground side of the circuit to ground at the door switch. I assume that they do this because it is easy. However that means there is always 12V at the lite. It sure makes for some weird electrical problems because of ground loops. That's what sometimes causes someone's turn signal to flash when they turn on the wipers or honk the horn as examples.
Old Nov 8, 2006 | 1:12 AM
Christina's Avatar
Thank you guys for your help. I really appreciate it!
Get this, I thought it was coming from the passenger side....because when I make a left turn (throwing the weight to the right) it seemed to flicker. BUT, throw ALL of that out the window. Went outside after I had been couple of hours, trying to decide if I should remove the fuse to save the battery.... as I was standing there....on went the lights!
Strange, isn't it? I'm leaning towards my original thought, 'Betsy' is just possessed!!
paulg_ca
Oct 24, 2014 5:42 PM
Jet-Unit
Jan 22, 2014 9:21 AM
nysmedic
May 13, 2013 10:04 PM
beckya99
Jul 12, 2011 12:29 PM
KBX500
Nov 4, 2006 9:53 PM
