Intermittent #6 Cylinder miss
Old Jul 26, 2018 | 10:20 PM
jsully's Avatar
Default Intermittent #6 Cylinder miss
2009 Suburban 5.3L active engine management. #6 cylinder misfire intermittently at the same time #6 drops out Stabilitrak, and traction control warnings come on. When #6 starts firing all Stabilitrak, traction control warnings go off. Seems that hitting a bump causes the issue to either occur, or go away. Might be coincidental with the bump, but pretty sure that is what happens.
Old Jul 27, 2018 | 12:55 AM
oilcanhenry's Avatar
Thumbs up
If you don't have an OBD II code reader, you can buy one, or most auto stores will run the codes for you. Post any OBD II codes here so we can help you.
Old Jul 27, 2018 | 10:12 AM
jsully's Avatar
I have a code reader, that is how I know #6 is where the miss is located. My code reader does not read issues with the Stabiitrack or Traction control. My confusion is how is the Stabilitrack, traction control connected to the misfire. Both the cylinder miss and the Stabilitrack, traction control occur simultaneously, and go away together. Plugs and wires were replaced about 3,000 miles back. Also from reading on this forum taking it to a dealer doesn't seem to be an answer. The dealers discussed do not seem to have a clue, and just throw parts at the problem. I did stop at one dealership, quickly determined they weren't able to help me.
Old Jul 27, 2018 | 10:33 AM
kevinkpk's Avatar
I'm thinking, and I should know since I own a 2003, and had a 2000 change coil pack with another cylinder, see if it follows
Old Jul 27, 2018 | 11:18 AM
jsully's Avatar
Swapping coils was on my list. I am getting up there in years, so it's difficult to access. I have checked the obvious, loose wires etc, so coil is next,
Old Jul 27, 2018 | 1:52 PM
jsully's Avatar
Switched coils, nothing changes, still recording misfires on #6, stabilitrack still service needed. Waiting for engine to cool so I can switch plugs to see if the miss follows. Still not understanding why stabilitrack is involved.
Old Jul 27, 2018 | 1:57 PM
kevinkpk's Avatar
Plug, if that's not it, swap plug wire. I don't understand the stabilitrack either. Hopefully tech 2 or shark will add something.
Old Jul 27, 2018 | 2:00 PM
kevinkpk's Avatar
Miles on the engine? Is the misfire frequent, as in every time you drive it?
Old Jul 27, 2018 | 2:18 PM
jsully's Avatar
130,000miles on engine. At the moment it is a constant problem, but it has been intermittent, as much as 1,000 miles between incidents. Miss is obvious, code reader is only needed to indicate cylinder involved. When it quits everything is normal, no warnings or service engine lights. Engine should be cool enough to change plugs/wires. I'll see what that does.
Old Jul 27, 2018 | 3:13 PM
kevinkpk's Avatar
Hope it's a plug, or wire, else it might be a burnt valve.
