Intermittent Door Lock Cycling / Chime Operation Wont stop ringing / Rear Access Open
Old Dec 25, 2018 | 4:04 AM
Supurrban's Avatar
Unhappy Intermittent Door Lock Cycling / Chime Operation Wont stop ringing / Rear Access Open
Merry xmas folk.
I have a 2010 Suburban and I have issues with Intermittent Door Lock Cycling / Chime Operation Wont stop ringing / Rear Access Open although its closed and today my battery is dead.
Does anyone have the same issues as I described and fix to this?
Old Dec 25, 2018 | 4:46 PM
Welcome to the forum.
Since you said your battery was dead, I would have it fully charged and load tested to see if it's still good. Sometimes a low battery will cause electronics to go bat **** crazy.
Old Dec 25, 2018 | 6:33 PM
intheburbs's Avatar
Low voltage usually is the cause of door lock cycling. Check the battery, alternator, and if they're both ok, start checking your grounds.
Old Dec 25, 2018 | 11:18 PM
Supurrban's Avatar
thank you for the reply sir. what particular ground should i check sir?
Old Dec 25, 2018 | 11:19 PM
Supurrban's Avatar
i will try this later sir. thanks
Old Dec 27, 2018 | 12:09 AM
Kazoocruiser's Avatar
From: Currently the Candian Gander is wintering over in New York.
Originally Posted by Supurrban
Merry xmas folk.
Like whatever everyone else said. Plus check your battery cables..They might be corroded and so could the battery terminals
Old Dec 27, 2018 | 2:24 AM
Supurrban's Avatar
Default Battery change and it's still drad
I change to a new battery. And today I try to start the car and had same issues :-(
Old Dec 27, 2018 | 6:10 AM
Supurrban's Avatar
So here I had the new battery and had the car stayed overnight. Then today this happened.
Old Dec 30, 2018 | 11:09 PM
Supurrban's Avatar
yesterday had change the negative wire. i just cold started the engine and still have the same issue. the mechanic check with a scan tool and there was no errer code came out. what options should i do?
Old Dec 31, 2018 | 12:30 AM
Benzo781's Avatar
I found a site that Chevy list a running tally of problems wrong with MY PERSONAL VEHICLE for years!!!!! It tells mechanics the problems and how to FIX it!!!
