ip
Old Apr 12, 2017 | 5:19 AM
IvoB's Avatar
Default ip
good day ,
In the interior lamp case .. what do you mean bij "IP" .. is this the dash ??
I am from Holand ( Europe ) so .. please help me out .
I am trying to locate the dome ( interior ) light relay or module from a 1996 Chevrolet Express 1500 ( 5.7 ltr engine ) conversion van . I suspect the relay of draining my battery . When i pull the 40 amps fuse ( engine compartment ) , the draining stops .
Can you help me ?
Ivo boelee
ivoboelee@hotmail.com
0031619000706
Old Apr 12, 2017 | 6:20 PM
"IP" usually means Instrument Panel yes the dash lamps. Generally, where you find the fuse the relay is nearby, not sure if the interior lights have a relay, but you might check the door switch , it's probably bad.
