iPod Annoyance - USB Wiring Question
#11
Sqrl,
Due to the info garnered at Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers, I now have a circuit design and have a relay spec'd from mouser that would work. I have the capacitors and resistors needed on-hand and have ordered the relay. Thank you for that direction and inspiration!
I understand that I could build a box "external" to the vehicle, but the last thing I really want is more clutter in the console area. We cut into the vehicle's wiring for all matter of things, so I am not that concerned about that aspect. However, I would prefer to install it in the dash area since access is far simpler there.
So, does anybody know where that USB line terminates?
#13
status?
ChuckinTX: I'm still waiting for photos and a write up here
thanks!
I've been busy rebuilding a '99 GTX LTD w/a 130 HP engine... (jet ski) I pulled the engine the other day, sent it for a rebuild, then last night cleaned up the hull and inside. Also replaced all the lights and trailer wiring...
SEA-DOO: Technical Specifications
should do 62-65 once I'm done with it, and everything should work as well...
it will be for sale this spring, with a warranty on the engine.
so, anyway, that's my project
thanks!
#14
Just a note, I have 3 diffrent I-Pod touch one 5th gen and two older ones. The 5th gen and one old one both have the same problem. You plug them in and everything works fine until you turn the vehicle off and back on it wont pick up the I-Pod. Now one of the older one works flawlessly. The ONLY thing I can find between the 3 is that the one that works has not been updated. Its still running on 4.1 while the other two are 5.1 and 6.1. Not much to go on but from what I can guess is that Apples ne updates are not compatible with the software in the vehicle
rwillaims94
October 9th, 2013 5:40 PM
stsmith5150
11
August 13th, 2010 10:13 PM
