Issue with heated seat - pleas help!
Old Sep 28, 2012 | 12:55 PM
CarolinaJ's Avatar
Default Issue with heated seat - pleas help!
I have a 2003 LT Suburban, all of a sudden as soon as you turn the truck on the driver side heated seat turns on by itself, then it goes from high to medium to low and then stars all over again, all on its own!!! What the heck?!! If we turn it off manually it stays off for like a few minutes and then starts again.
Old Oct 8, 2012 | 9:41 AM
Sud's Avatar
Sud
Having the exact same problem on a 04 Suburban. Just started to day...I'll let you know what I find out.
Old Oct 9, 2012 | 9:42 AM
CarolinaJ's Avatar
Actually ours stopped doing it after two days. Our guess is that hubby left the window open while it was raining and some how water got to it.
Old Oct 11, 2012 | 4:16 PM
Did you check the fuse?
Old Oct 13, 2012 | 3:13 PM
staggerlee's Avatar
Curious as to what the fuse would have to do with it?
Its just a fuse, its good or bad thats all.
Thanks,
Lee
Old Oct 14, 2012 | 4:05 PM
P Kent Gravely's Avatar
Yeah, it would be a relay, not a fuse. The symptoms you describe sounds like the computer controlling a timer is confused. Mine has recently started to not heat the seat, just the back, If I turn the back on, its works great, if I turn the bottom and back, it clicks off after about 30 seconds.
Rbahri5206
Feb 14, 2015 3:02 PM
2004TahoeZ71
Apr 1, 2009 1:49 PM
Sergio_t1
Avalanche
Mar 17, 2008 6:57 PM
slt780
Aug 6, 2007 10:42 AM
Mark_MS
Feb 12, 2007 2:24 PM
