K1500 5.7 surging
Old Jul 26, 2020 | 9:19 AM
Wds12384's Avatar
Default K1500 5.7 surging
1995 suburban 4wd.
Engine surges every few seconds with the ac clutch trying to engage. The ac and heater are off, haven't had ac in this truck in years. Water pump is bad and have a hole in the heater hose disconnect. Would one of these cause my problem or should I be looking some where else?
Old Jul 26, 2020 | 8:04 PM
oilcanhenry's Avatar
Originally Posted by Wds12384
1995 suburban 4wd.
Does it do this if the A/C clutch wires are disconnected?
Old Jul 30, 2020 | 4:56 AM
Wds12384's Avatar
Default Fixed?
So after some online searching, I came across a similar problem and tried their solution of turning the vent control to the floor position (ac and heater still off, just turned the positioner) and the surging has stopped. Not sure what to make of this though.
Old Jul 30, 2020 | 8:26 AM
Little Bear's Avatar
AC is turned on in the defrost position, going to floor turns it off. Disconnecting the connector to the compressor clutch will end the problem and you will be able to use the defrost position with no issues.
Locallyhatedk1500
1988 - 1998 (GMT400)
Jun 14, 2018 5:36 PM
Kasey Smotherman
Jun 5, 2018 6:56 PM
deapet
May 2, 2017 8:48 PM
deapet
May 2, 2017 8:47 PM
Drakota44
Jan 28, 2012 9:41 PM
