Kenwood CCD-900
Old Mar 20, 2007 | 4:25 PM
genestoy's Avatar
Default Kenwood CCD-900
I posted this in the sticky about about the camera setup but appears nobody is looking at that thread anymore so will try here.
For those of you that have installed the Kenwood CCD-900 backup camera--
1) Does the nav radio need to be dealer flashed after installing the Kenwood CCD-900?
2) Can the Kenwood camera "see" a trailer ball so you can back up and stop directly under the trailer tongue?
Thanks
Old Mar 21, 2007 | 11:34 AM
engine2's Avatar
Default RE: Kenwood CCD-900
Check out below thread. You do need a reflash for new camera install to work.
https://chevroletforum.com/m_14877/tm.htm
Old Mar 21, 2007 | 4:28 PM
konasmrz's Avatar
ORIGINAL: genestoy
Thanks
It all depends on whether the rear camera option was selected at the time of your last flash. When you put your vehicle in reverse if you get a black screen with a warning at the top to "look around for other objects" then you DO NOT need to have it flashed. The NAV video input is active. If no black screen then yes you will have to have it flashed to enable the rear camera video input.
In my case, my NAV was new in the box when I installed it (default is everything turned on) and it has never been flashed. Camera, RSE, everything was enabled.
dtachia
Apr 23, 2011 12:53 AM
joestangman
Jan 30, 2009 3:58 PM
flstfse
Mar 24, 2008 7:26 PM
AndHart120
Sep 20, 2007 12:35 PM
genestoy
Mar 30, 2007 12:15 AM
