keyless entry
Old Dec 30, 2007 | 9:33 AM
07chevsub's Avatar
Default keyless entry
2007 Chev Suburban
The keyless entry will not work once the vehicle has sat idle for more than thirty seconds. The vehicle will only respond to the remotes if the door is unlocked with the key, the ignition is turned on, or right after the vehicle is shut down. After doing any of those three things, the remotes become inoperable again after thirty seconds.
Can someone help me with this...it is driving me nuts!
Old Jan 8, 2008 | 8:59 PM
scossey's Avatar
Default RE: keyless entry
I have the exact same problem. It occured immediately after having the oil changed at the dealership. It does the same thing with both remotes. I have a suspicion that it might have something to do with the dealership resetting the oil life indicator, or maybe they applied some type of ECM update while it was in. Just speculating, I have not contacted them yet about it.
Old Jan 9, 2008 | 10:52 AM
ZX1100F1's Avatar
Sometimes the dealer will apply programming updates that can result in the RKE problems that you have.
To resolve this concern, Remove the (10 amp) DSM fuse for 20 seconds and then reinstall and recheck for the condition, the DSM fuse is located on the driver side of the instrument panel, you will have to open the driver's door and pop the plastic panel off to access the fuse block.
Old Jan 9, 2008 | 12:17 PM
scossey's Avatar
Thanks very much. That took care of it.
black07LTZ
Feb 3, 2020 6:58 PM
sadalius
Cobalt
Nov 9, 2013 1:50 PM
93Miata
Astro
Mar 1, 2008 1:49 AM
terryrowe007
May 29, 2006 12:30 AM
