Knocking sounds from water pump
Old Aug 3, 2023 | 6:54 PM
ImFunctionz's Avatar
Default Knocking sounds from water pump
I have a 2016 Suburban and had recently done a cam swap/DoD delete. I had finished up and when I was tuning it I noticed the knock retard kept kicking on infrequently at idle. I tried to listen to where it was coming from and it was from the front of the engine. I originally thought it was chain slap or a bad pump/pulley but after further investigation via stethoscope it is coming directly from the thermostat housing. I plan to replace the thermostat and hopefully fix the problem but I would like to know if anyone else had similar problems or other possibilities if this isn’t the problem.
Old Aug 8, 2023 | 12:19 AM
Default Update
I replaced the thermostat with no change, going to check under timing cover to see if there is any indication of chain slap. The reason I initially believed it was the water pump was because I had a high fluctuation of coolant in the reservoir at idle. I now realize it is probably due to the frequency of power spikes from the cam not being very consistent. If the timing chain is not the problem then I suppose I’ll be pulling the heads to inspect my valves and pistons.
Keegansherman
Jun 27, 2017 9:46 PM
Doogleass
May 9, 2011 9:21 PM
joejaju
Mar 28, 2008 6:32 PM
bracing248
Oct 23, 2007 10:45 PM
trevor0520
Dec 20, 2006 5:43 PM
