Leaky Oring on new AC reciever/dryer to evaporator, 97 Suburban
Old Jul 7, 2012 | 11:49 PM
dslemaire's Avatar
Default Leaky Oring on new AC reciever/dryer to evaporator, 97 Suburban
Recently I opened my AC system on my 97 Suburban to replace the hoses with the high and low pressure valves and the condenser. So I also replaced the receiver/dryer with a new one from NAPA. The new one came with Orings, but when I put them on they seemed to be too small on the side going to the evaporator. So I pulled it off and put on a little thicker Oring I got from an Autozone kit. It seemed to hold, for a while. But then after about 2 weeks it started to leak again.
I tightened it more, but I still have some dye leaking out when it shuts down. Running it doesn't seem to leak. But being low pressure side, when I shut down it starts to leak a little and I can see a very small bubble of dye coming out sometimes. With a sniffer I don't pick up a leak with the compressor running. But after I shut down and the pressure equalizes it starts beeping on me that there's a leak.
I did have a pinhole leak in one of the rear lines on the low side, and put in some "super seal" which actually worked on the pinhole leak without replacing the rear line. I don't know if it will help on my oring leak on the dryer though?
I'm thinking of returning the dryer to NAPA and getting a different one and take a good look at the orings. It just seems bizarre that they are too skinny. When I removed the fitting going to the evaporator it was difficult and I was concerned about the threads. But I am able to get it tight, so I would think my real issue is still the oring.
Any suggestions, other than hoping super seal will plug it! ??
Thanks,
David
gosman
Nov 19, 2020 9:49 AM
hfd11
Jun 15, 2013 5:17 PM
hendrira
Aug 31, 2008 9:48 AM
