Left Bank Lean help
Old Jun 27, 2010 | 12:45 PM
mwranger's Avatar
Default Left Bank Lean help
Hello all...any help is much appreciated. (2002 Tahoe, 4WD, 5.3FlexFuel)
OBD P0174 showed up and I've replaced both upstream O2 sensors. The check engine light went off and the code disappeared.
Now the code is reappearing, as luck would have it when I was getting an inspection...
Any thoughts on what else would make the system run lean? It has brand new fuel filter, the plugs / wires are less than 2 years old. I'm going to clean the MAF sensor next....
thanks
Old Jun 27, 2010 | 5:27 PM
99er's Avatar
Maf sensor is where I would look next, then fuel pressure.
Old Jun 27, 2010 | 8:03 PM
MDTAHOE's Avatar
Professional Mechanic
O2 sensors will not cause a lean code they are what sees the lean condition. Plugs and wires have zero effect on fuel problem. If it where a bad or dirty MAF sensor you would also have a PO171 Lean bank 1. I would highly suspect a bad intake gasket. The gasket has been updated for this problem.
Old Jun 28, 2010 | 6:42 AM
dh1's Avatar
dh1
If it's only lean running on one bank, and not the other...you need to look at what would affect ONLY that bank. The MAF would affect both banks if it were malfunctioning.
Look for anyplace that you can get additional air introduced into the intake between the MAF and the block. Any air intrusion beyond the MAF would be not measured by the computer to calculate the air fuel mixture, leading to a lean running and possibly driveability problem. Particularly like MDTAHOE said, the intake manifold. It is where the air is separated and diverted into each bank.
My money is on a bad intake gasket
Old Jun 29, 2010 | 9:36 PM
mwranger's Avatar
Thanks all for the help. It now does show both banks lean so I'm going MAF first....God help me if I have to replace the intake manifold! Got quoted $1400 labor from Pep Boys today on it..
Old Jun 29, 2010 | 10:04 PM
MDTAHOE's Avatar
Quote seems very high only calls for 2.6 hours. Even at $100.00 per hour that's $260 for labor and gasket set from dealer is around $100.00. No coolant or oil needed. You should call someone else. Even the dealer would be way less money.
Old Jun 30, 2010 | 6:23 AM
dh1's Avatar
dh1
If they quoted you that much labor, I would never take your car there ever again. A skilled mechanic should be able to remove and re-install both cylinder heads with less labor than that. Even if that number includes the part price, they are screwing you.
It took me 2 hours to remove and re-install my intake manifold, and it was my first time. It has to be removed to replace the knock sensors. A good bit of that 2 hours was figuring out how to remove the fuel rails without damaging them, then looking for the o-rings from the injectors. Like I said, a skilled mechanic could do it in 1.5 hours in my estimation.
Just curious why you suspect your MAF? In my experience if it was going bad it would also be tossing an error code. Not always, but normally.
Old Jul 13, 2010 | 1:14 PM
mwranger's Avatar
Default got it..
Thanks all for the help. I decided to start from the air filter in...thinking I'd try the cheap fixes first.
Turns out replacing the MAF sensor did the trick. At least the codes cleared and I got my inspection sticker!
I'm sure the intake manifold gaskets will go soon...but at 250K miles she's still running strong!
Old Jul 15, 2010 | 2:30 PM
Glad you got it fixed, thanks for reporting the solution.
jphurst36
2007 - 2013 (GMT900)
36
Feb 26, 2024 3:23 PM
TylerWalker
12
Aug 14, 2022 12:22 PM
debo
Jul 8, 2022 8:16 AM
jimmydow1
Feb 17, 2011 8:12 PM
jimmydow1
Feb 12, 2011 12:56 PM
