Looking to replace engine ecu question 07 tahoe
Old Apr 8, 2020 | 10:02 PM
Jose Manzo's Avatar
Default Looking to replace engine ecu question 07 tahoe
Hi my name is jose my tahoes engine when out on me looking to replace with an engine that came of an same year tahoe with with the 8th digit on vin on both is 0 will i need to change the ecu of use the current one in my old engine need help would help. THANK YOU
Old Apr 9, 2020 | 7:35 AM
sfcjones's Avatar
Nope, The ECM will support the same year model of any engine you put in the Tahoe. I am working on 300k miles on my 2007 Tahoe and am thinking about putting in a 6.2 out of a same year SUV like the Cadillac or Yukon Denali. They share the same ECU. I am not aware of any tuning that is required but you could call HP Tuning or Black Bear Tuning to verify.
So the short answer is you can keep your ECM with the replacement engine.
Old Apr 9, 2020 | 8:53 AM
the crankshaft position sensor variation relearn will have to be performed or false misfire dtc will set at high rpms.
eric cuevas
Apr 4, 2020 7:24 AM
ericch
May 26, 2007 12:54 AM
1hot650r
Nov 21, 2006 1:38 AM
sdfd504
Oct 19, 2006 6:12 PM
