Low Idle??
Old Apr 16, 2012 | 1:49 PM
CarolinaJ's Avatar
Question Low Idle??
We have a 2003 Suburban that stalls whenever we come to a stop, like at a stop sign or traffic light, in order for it not to stall we have to step on the brake while maintaining the other food on the gas to keep the idle a little high. This doesn't happen if the car is on P. This is why hubby thinks it is he idle. Has anyone had this problem? How was it fixed?
Thank you so much for your time.
Old Apr 16, 2012 | 8:57 PM
Welcome to the forum.
First, you should never place food on the gas. JK
I suspect the Idle Air Control (IAC) may be dirty or bad. Try cleaning it and the rest of the throttle body.
Old Apr 17, 2012 | 6:31 AM
CarolinaJ's Avatar
Thank you for your reply, is that hard to do??? Someone told me I need it to have it reprogrammed??
Old Apr 17, 2012 | 6:11 PM
Just remove it and clean the carbon off. I think the computer will reprogram during driving.
Old May 23, 2012 | 8:52 AM
CarolinaJ's Avatar
I wanted to thank you for your IAC advice. Hubby did just that and he said it was so dirty it was horrible. Once he cleaned it... What a difference!!!! WOW!!! The truck runs so nice and smooth now. Thank you thank you thank you!!!!!!
Old May 23, 2012 | 8:28 PM
You're welcome, thanks for reporting back. Really helps the forum when others find this.
Old May 23, 2012 | 10:29 PM
playboy's Avatar
hey had the same problem. but it wouldnt stall.. once it did but just kinda slowly clugged as if it wanted to die. awesome when driving. so.popped the hood and adjusted the idle cable to "automatically do the brake foot peddle".. is that bad?
Old May 24, 2012 | 8:05 AM
Welcome to the forum...
Not so much bad, but it is going to be wasteful for fuel and a band aide for the real problem...
I would suggest cleaning the throttle body and plate as well as the IAC, and remove any mod you did to the cable... if you after that you still have an idle problem more troubleshooting is needed...
Old May 24, 2012 | 11:37 AM
hicksvilleshick's Avatar
This is wisdom... heed it.
:chug:
the68
Jul 21, 2013 1:09 PM
MikeShirk
Dec 31, 2012 10:39 AM
vanmanpdx
Jul 9, 2012 2:04 PM
wresleu
Astro
Jan 2, 2007 5:56 PM
toymister
Sep 6, 2006 1:18 AM
