Low oil pressure on my 2011 5.3L, but wait!
Did you ever figure out the oil pressure issue? I am experiencing exactly every symptom as you, cold it runs at 35 to 45 psi depending on acceleration, once warm it doesn't go up past 30 even at full throttle and at idle when warm it goes as low as 10 to 15 psi and the engine is thumping. I've changed oil pressure switch, the screen under it, the oil pump, and the oil pickup tube o ring. None of these things changed any of the symptoms.
If your oil sending unit isn't plugged or defective that an awful low oil PSI at idle 30 to 40 pounds is more normal.Repairman54 is probably correct about the filter under the oil sending unit. I've been working on vehicles for a long time and its almost always the sender, not the gauge that has issues. It's a bear getting to that sender on your vehicle, but it's not that hard if done right. Lots of great YouTube videos on this sender removal will show you how to do it more easily than I could explain here. Make sure your throttle body isn't defective or dirty as well. Might be a good idea to add Seafoam or Techron Complete into your gasoline tank as well.
I replaced the screen. Same issue. Not sure what to do next.
mac_in_mt
Apr 28, 2022 3:19 AM
Shannon43
May 18, 2012 10:53 AM
Shannon43
Mar 24, 2012 7:27 AM
