Manifold Leak?
Old Apr 12, 2015 | 9:27 AM
Plimbob's Avatar
Default Manifold Leak?
What are the symptoms of a manifold gasket leak other than rough idle/miss?
Old Apr 12, 2015 | 9:51 AM
the fuel trim would be lean at idle but normal at 2500 rpm. if you have a 99 to 06 5.3L, its common.
Old Apr 13, 2015 | 12:20 PM
Plimbob's Avatar
Any chance I would be getting an intermittent coolant leak as well?
thanks,
Tim
Old Apr 13, 2015 | 7:52 PM
yep. it should be easy to see the wet trail left behind. and the model year is?
Old Apr 13, 2015 | 11:35 PM
mistaake's Avatar
Anything from 95 to 05 is common. Rough idle (vacuum leak), coolant in oil, coolant leak, could all be from this.
Old Apr 19, 2015 | 10:46 AM
Plimbob's Avatar
Hi Tech2
The Tahoe is a 2007 5.3. I have looked for a coolant trail and I can't find it.
It seems to be more prevalent after driving on the highway at 65-70 mph for awhile. Then park it in the garage and there will be a spot or two a quarter to half dollar in size. I'll wipe it up and then it won't leak for awhile.
I have pressure checked the cooling system and it doesn't lose pressure?
Thanks,
Tim
Old Apr 19, 2015 | 8:03 PM
Water pump seal?
HeavyChevyTom
Jul 25, 2012 9:23 AM
Shag
Jul 22, 2011 10:56 AM
LA1
Sep 23, 2009 9:20 PM
95wt
May 30, 2008 3:07 PM
vfilby
Dec 28, 2007 12:53 PM
