Material precipitating in Oil Filler cap
Old Feb 21, 2013 | 12:23 PM
banderson_27's Avatar
Default Material precipitating in Oil Filler cap
Thanks for the answers on my last post. I have a 2000 Chevy Tahoe and I noticed an off white material in the oil filler cap. It looks like white lithium grease but it's not greasy to the touch. This stuff was also in the oil breather line attached to the left valve cover. I read recently that this deposit is somewhat natural in some older model Tahoes because of condensation in cold conditions. Is this from anti freeze or ???.
Note: Didn't notice and water in the oil at last oil change
Thx for your help
BA
Old Feb 21, 2013 | 12:44 PM
kevinkpk's Avatar
Thx for your help
BA
That would be my guess. Check the anti-freeze level, are you having to add, and also the oil dipstick, is it overfull?
Old Feb 21, 2013 | 12:46 PM
kevinkpk's Avatar
Is it dexcool anti-freeze? My experieance is brown crap in the radiator with glycol (green)
Old Feb 21, 2013 | 9:05 PM
cleveland63b's Avatar
if you drive only short trips sometimes the condensation will form that white sludge due to the fact it doesn't heat up enough to evaporate
Old Feb 22, 2013 | 7:20 AM
Condensate would be my opinion as well...
Old Feb 25, 2013 | 4:31 PM
DoubleO7's Avatar
My 99 was leaking rad fluid into the oil pan. But not enough to discolor the oil one itty bit.
Anyways, the 5.7's of that era were notorious for intake gasket failures.
Some will leak into the lifter galley, some will leak to the outside.
I too had condensation on the underside of the oil filler cap. I never did have milky oil, but radiator fluid was getting to the oil pan.
Go ahead and touch the condensation under the cap with your finger, then taste it and spit. If you have a rad fluid leak, it will taste sweet.
If it is tasteless, it is regular straight water condensation due to not running the engine at full operating temp long enough to get rid of it.
I could taste antifreeze condensed to the inside of the oil filler cap.
And all condensation went away after replacing the intake manifold gaskets.
Old Feb 26, 2013 | 7:30 AM
Thanks !
I'll give it the old taste test
Just changed the oil two days ago and I didn't see any evidence of anti freeze..not tosay
it's not present. Good point though
Old Feb 28, 2013 | 9:27 PM
dexcool isnt sweet
IhateMyCorsica
Oct 27, 2012 3:06 PM
mob_boss251
Colorado
Mar 3, 2009 6:05 PM
CanJim
Jan 30, 2009 7:46 AM
BA002
Jun 20, 2008 11:13 AM
