Misfire mystery?
Old May 30, 2025 | 9:04 PM
JL1337's Avatar
Unhappy Misfire mystery?
Hello guys, I am having a misfire on cylinder 5 that I can't seem to get away from at all.
The P0305 code is not making a light on the gauge (it's pending) but I can still scan for it and slightly feel it at idle.
Vehicle: 2014 Chevy Suburban (Vin "0").
What I tried:
  • Moving the spark plug to a different cylinder (didn't do anything)
  • Moving coil and boot to a different cylinder and replacing said coil/boot (didn't do anything)
  • Replacing fuel injector (didn't do anything)
  • Compression test (good compression)
  • Head gasket leak test (no leak)
Other notes:
I replaced the head gasket some months ago, and one of the top small head bolts snapped due to a faulty torque wrench... I have yet to deal with it as my compression/head gasket are seemingly fine.
Any guidance is appreciated.
Old May 30, 2025 | 11:00 PM
JL1337's Avatar
Image attached shows two plugs; one from cylinder 1 (left, good) and one from cylinder 5 (right, misfire). Do they look alright?
Old Jun 2, 2025 | 3:53 AM
JL1337's Avatar
Update:
Took the valve cover off and inspected the push rods, something is definitely weird with the cylinder 5 intake push rod. It looks like it has this orange scratchy appearance on the end that is closest to the camshaft. I haven't been able to find anything about this online at all, no idea what this is. Anyone ever seen something like this?
Images push rod order (left to right): Intake 1, exhaust 1, intake 3, exhaust 3, intake 5, exhaust 5.
Old Jun 3, 2025 | 10:43 AM
The head bolt that snapped off, was it near #5 cylinder? The orange appearance on the push rod, is it rust? Did you check the lifter?
Old Jun 3, 2025 | 9:23 PM
JL1337's Avatar
The snapped head bolt is near cylinder 5, yes. The orange stuff has an oil/grimy texture, wipes off easy. Haven't checked the lifters or cam yet.
Old Jun 4, 2025 | 11:25 AM
I think you need to replace the broken off head bolt.
Mr_Professional
HHR
13
Jun 4, 2022 4:04 AM
96 CC
Nov 11, 2021 10:43 PM
deej91
Mar 11, 2015 12:12 PM
JJB
Oct 23, 2010 10:14 PM
steelhorse123
Dec 25, 2008 12:02 PM
