Misfire p0300 and popping
Old Jul 11, 2021 | 5:01 PM
Curtis Brown's Avatar
Default Misfire p0300 and popping
Hi i have a 97 chevy suburban k1500. Set distributor...cam retard reading 0 & +1 but I'm hearing popping from tail pipe. What could be happening? Do I need plugs?
Old Jul 11, 2021 | 11:22 PM
oilcanhenry's Avatar
Pooping from the muffler or exhaust system is usually unburned gasoline igniting. The misfire allows the fuel into your exhaust. Your P0300 means you have a misfire in one or more cylinders. Could be plugs or a bad coil as well. Might also be a good time to check your cylinder compression levels
Invisions1
Dec 4, 2020 6:37 PM
ncagliola
Sep 29, 2013 1:19 PM
one8thursize
Sep 23, 2012 1:33 PM
jpolk1
Mar 2, 2012 4:07 PM
