Misfire? Running rough around 50 mph and 12 to 1500 rpm?
Old Sep 27, 2011 | 6:24 PM
kronzy's Avatar
Default Misfire? Running rough around 50 mph and 12 to 1500 rpm?
My 2001, 150000 miles, Sub just started running a bit rough, possibly a misfire, but not sure? Around 45 to 50 mph, 1200 to 1500 rpm, most pronounced going uphill, engine seems to skip, run rough, misfire?, If i downshift it doesn't seem to do it? Normal idle and low speed, smooth running. There isn't any check engine light on. I thought about plugs and new wires, but some of the stuff I have read here doesn't really back that up as a solution. Possibly and O2 sensor although I thought I would get a check engine light for something.
Does anyone have any thoughts or recommendations before spending a $1000 with mechanic checking things of the list. Thanks in advance for any help!!
Old Sep 28, 2011 | 12:16 PM
RacerX's Avatar
may be a pending code in the computer...scan to see.
Old Sep 28, 2011 | 8:35 PM
2001, 150K miles I'd start with a good clean tune up...run a few bottles of injector cleaner, check the fuel pressure... clean up the MAF sensor...
Old Oct 3, 2011 | 10:58 AM
slw210's Avatar
Hook up a vacuum gauge and read THIS.
Old Oct 3, 2011 | 7:07 PM
loosebearing's Avatar
More pronounced going up hill... might be the catalyst stopped up.
Old Apr 14, 2013 | 8:48 AM
hoghunter03's Avatar
My 2005 z71 does the same thing except hills don't seem to affect it
Old Apr 18, 2013 | 8:37 PM
Joe In NY's Avatar
ummm yeah. you got clogged cats if you have zero vacuum....
Schooner
Jul 11, 2024 10:08 PM
85fordyota
Jun 27, 2013 11:26 PM
alamozgreat
Aug 17, 2011 11:08 PM
ventureman
Jul 25, 2010 4:21 PM
atlbigboi
Nov 22, 2007 9:16 AM
