more torque
Old Mar 31, 2010 | 6:55 PM
mikejames's Avatar
Default more torque
i have an 02 suburban 5.3, it was fine and towed whatever i wanted in the nice flat virginia, but now i just moved to the extreme hills of west virginia and its gettinig its a$$ wipped. its hard to tow a 8x10 utility trailer with a few things on it. on steep hills on the interstate i drop it to third and watch the speed drop then it downshifts from there and screams back up to speed at 4500 rpms. i have a 6.0 longblock already, was thinking a nice cam in a 6 liter might do it but what are you guys getting from the cam swap in a 6 liter? wipple charger is to much money, would buy a new truck first.
Old Mar 31, 2010 | 7:04 PM
nauticstar87's Avatar
If you do a 6.0 swap, you need a new computer, and the harnesses.
I would suggest a custom tune. and a few bolt ons. CAI, exhaust. After that, a Blackbear Tune, will open up your burban a lot.
A gear swap would help teh most though. Even more than swapping a 6.0 in. I would suggest 4.10s.
Old Mar 31, 2010 | 8:49 PM
MDTAHOE's Avatar
Professional Mechanic
I second the Black Bear Tune.
Old Mar 31, 2010 | 9:25 PM
Thumper_ehhhhh's Avatar
If your having troubles towing a utility trailer you might have some other issues. I tow a 5500lb travel trailer with no problems up 6% grades downshifted in 3rd without losing any speed. I too have a 5.3. It could also be the gears you are running. I have 3.73 I beleive. if you have 3.41 then that could be your problem. Inside you glove box there should be a bunch of 3 digit codes. RPO codes you can check them online here to see what gears you have. http://www.gm-trucks.com/rpo-code-lookup/
Old Mar 31, 2010 | 10:02 PM
maxxman04's Avatar
i agree with the gear change. even having a shop set it up is alot cheaper than 6.0 swap. as well as a custom tune and such mentioned above.
Old Mar 31, 2010 | 11:59 PM
s34n's Avatar
i vote for a gear change to 4.10s is it 4wd or 2 wd drive?
Old Apr 1, 2010 | 4:04 PM
If you get a shop to do it which I sudjest. Make sure they can reprogram your speedo for you.
Old Apr 1, 2010 | 4:17 PM
mudmaniac's Avatar
Ride of the Month
May 2009
The motor has plenty of power, go with the gear change.
jp_it_bikeco
Jul 9, 2013 8:22 AM
Chevrolet Forum News
May 31, 2013 12:38 PM
john4a73
Apr 23, 2007 7:29 PM
jbperry
Dec 18, 2005 11:31 PM
